Using Fusor 108B, Riveted Stringer to Leading Edge Wrap and rivet the Leading Edge Wrap to the Ribs.
Placed masking tape on the Leading Edge Spar and Trailing Edge spar as noted to eliminate excess adhesive running. We had already removed the Anodizing from the spas as per manual.
Bonded the Leading Edge Wrap and the Upper root Skin to the spars using Fusor 108B.
Covered the possible areas where the adhesive may bond the board and the metal together with wax paper. Clamped down the areas and let them sit overnight.
