As per manual drill 2 #40 holes and cleo'd them to help hold tip wrap in place.
Transferred drilled #30 and cleo'd to tip rib.
Transferred drilled #30 using the leading edge wrap as a guide and cleo'd to the leading edge wrap and rib #11. We will rivet after the Leading Edge Wrap is bonded.
Pulled the Tip Wrap to back side of the Leading Edge Wrap and Tip Bow. Transferred Drill #30 and Cleo'd. Had to trim the tip wrap to provide rib clips.
Drilled Tip Wrap #40 to Match Pre-drilled holes in Tip Rib.
