Final drilled bottom skin holes. Deburred skin edges. Note image 2. This is where one of the nut plate attach rivets line up with the gap in inboard wing flange. This nutplate rivet will only be riveted to the skin and the shop head will fit into the gap. I filed the rib flanges a bit to give enough room. The remaining nutplate attach rivets will go through the skin and the flange.
