Leak check left tank. Used balloon and bike pump to pressurize tank. Leaks were found at finger strainer and fuel drain. These were tightened to eliminate leak. Additional leak was found again at the outboard tooling hole that was patched. Additional pro-seal was applied here but did not cure long enough so a pin hole formed. I put tape over this hole and the balloon kept presure overnight. This hole will be patched again, left to cure, and then a last check using the manometer method will be used. Using soapy solution the rest of the tank was checked with no leaks found - yay!!
