I riveted the rear spar doubler to the rear spar using my pneumatic rivet squeezer. Works great!
The forward lower portion of the rear spar was riveted with flush rivets. There are two holes that were left open. These holes are used as attach points when the vertical stabilizer is attached to the fuselage.
