Installed 2 more bolts on each wing spar, so I now have 2 on the top and one on the bottom holding the main spars to the center section. Measured and cut a 4 5/64" block to use in setting the wing incidence. Leveled the fuselage laterally and longitudinally. Set preliminary wing incidence. Achieved 0.0 degrees on each wing.
