Put retainers in top cowl and inserted the studs. Attached to the firewal flanges and screwed in the studs to give a tight fit. Began fitting lower cowl. Had to sand some of the cowl to fit along the firewall sides and bottom. Marked the holes for step drilling and drilled holes.
