Brief Description: F6111 right side, F750 right side
Fitted F6111 on the right side. Drilled all holes and deburred. Deburred holes in F788, and top stringers. Removed top forward skin. Began fitting up F750 on the right side. Noticed I still needed to drill holes in F722 for rudder cable grommet on both sides an drilled them and placed grommet. Clecoed in F750 and drilled top three holes, rear holes already drilled. Removed F750 and deburred holes and dimpled rear three holes. Dimpled holes in F706. Clecoed F750 back and then riveted. Did not install nutplate onto both F722 and F750 at forward two holes as I had already installed the nutplates on the F722 previously. Therefore the forward edge of F750 will be held in with the screw only which is fine.
