Settled on final location of elevator servo after much agonizing. Began cutting mounting plates and brackets for mounting the elevator servo. Made several efforts before settling on design that should work. After cutting plates and brackets drilled preliminary holes in mounting plate to bottom skin. Some will be riveted, others screwed in to allow for removal of servo, which will be difficult but not impossible once final mounting is done. May have made a design error that makes it more difficult than I wanted but it will still work.
