Received VP-X PDU this week. Began to install and finish up wiring. Needed to do some re-wiring to the Skyview DB39 connectors so had to pull those both apart which was a major pain. This was to be able to display VP-X info on the Dynon display so had to wire from the PDU to Serial Port 4. Also, since I have 2 GPS antenna and only had 1 serial port left, I was instructed by Dynon to wire 1 antenna each to each display on Serail Port 5. Ready to finish up wiring, mostly zip tying and final preparation for putting the top skin on. Lost a couple of months but it will be okay.
