Bled the brakes today. Bought an oil pumper from Tractor supply and some tubing to use. Filled the oil pumper up and attached the clear tubing to it and primed the tubing before attaching to the brake bleeder fitting. Pumped in brake fluid and promptly discovered some loose fittings. Tightened all fittings and restarted the bleeding process. Did right side first and then left side. Worked excellently and have nice firm brake pedals. Spent a lot of time zip tying a lot of the wiring between the panel and firewall that was undone when the VP-400 was exchanged for the VP-X.
