Brief Description: Blast tube for fuel pump shroud, zip ties
Received the flange I needed to install on the back of the left side rear baffle for blast tube to the mechanical fuel pump. Drilled necessary holes, deburred, and riveted in the flange. Attached scat tubes to flange and to fule pump shroud using SS hose clamps. Zip tied together a lot of the wiring I had to cut the zip ties to determine wire routings yesterday.
