Not as productive a day as I had hoped. Things didn't seem to come together today. I played with the routing of the plug wires from the P-Mags to the spark plugs and sorted the routes for the most part. The wires are a little long in my opinion but I am not going to shorten them up. I'll just select a slightly longer route. I also drilled holes in the aft baffles for the blast tubes that will cool the P-Mags. Not sure how I'll get them to stay in position but I'll figure it out. Started working on the route for the primer tubing from the primer pump to the cylinder heads. Stumped a little bit and want to purchase a fitting to pass through the aft baffle which will help secure it and make it easier to take off if necessary.
