Emailed Mike Goodson at SteinAir who did my panel and asked him to clear up the confusion I had with wiring the master switch and the alternator. As it turns out he had the diagram wrong for use with the VP-400 and he sent me a new drawng and a picture of how to wire it. I then was able to wire the Master switch to the VP and to the Battery Contactor. I also finished the connection to Starter Switch. I then began to wire the VP Display connections which are all the switches for the Nav lights, strobes, landing lights, fuel pump, avionics, pitot, etc. I crimped all the pins on and assmebled them into the J103 connector. I also wired in the three wires to the J101 connector and some of the wires to the J104 connector.
