BRUCE'S WEB SITE
Date:  4-6-2013
Number of Hours:  6.75
Brief Description:  Wiring...
Pulled a lot of wire today trying to finish up with all of the wire pulls throught the fuselage to the VP-400. Pulled power and ground wire for the Landing lights, both wings Nav lights, and the Pitot heat. Also, pulled the power, ground, and data wires for the Capacitive Fuel Sensors on each side. Once I had all these wires pulled I began to install wires into the J10 connector to the VP-400 PDU1. Per normal procedure I crimped on pins to each of the wires as I was installing them and labeled them as I went. I installed the Starter Switch power wire to J10 but I think this may be wrong so I have to check it. I'm not sure now in retrospect as I type this whether I have it right. I installed the GMA 350 power wre into P2, the EFIS MFD into P3, the APServo power into P4, the left HID Landing light into P5, the Pitot Heat power wire into P6 and the Ground wire to P9. P10 is left open for a backup alternator which I will not have. I also installed several of the ground wires to the grounding block as required but left a few uninstalled right now to figure out how to gang some of them together since I will run out of tabs on the ground block.
Most of the J10 done
Wires for R Nav and Landing Lts
Wires for L Nav, Landing Lts, and Pitot Heat
