Installed the 1/8 NPT nipple and Tee to be able to send oil pressure to the oil pressure sensor and the Hobbs pressure switch. Wired the Hobbs switch to the ground block and to the panel bt the panel terminal is not installed yet. Worked on the wiring for te Dynon ADAHRS. Had to use the "Net Splitter" I got from Dynon and cut off the male connector and install a female connector because the Dynon Hub is all male pin connectors. Spliced the wires with butt connectors and covered with heat shrink. Connected the connectors and zip tied for stability. Inserted pins for the OAT sensors in the connectors and conected to the ADAHRS units. Zip tied the service loops to the conduit at the bottom of the fuselage. Stein Air had made up some wiring harnesses for the servos but had to cut off the roll servo connector to run through the conduit so it can get out to the right wing. Will also have to change one of the connectors for the pitch servo since they are both the same gender. Connected the other end of the harness to the Dynon Hub. Need to order some wire splices to do the power wires for the servos. Screwed in the Male fittings to the Dynon ADAHRS units but will have to replace some because I need different fittings to get pitot/static/AOA to all ports on the Dynon ADAHRS and the Vertical Power GADAHRS. A lot of time today for few accomplishments.
