Had a pretty good day all in all. Figured out where to mount the Dynon modules. Decided to mount the EMS, Transponder, and the two Skyview backup batteries on the forward side of the intermediate subpanel between the panel and the firewall. Once I located where I wanted things I drilled all holes for screws. I removed the instrument panel for better access and drilled and deburred holes for K1000-8 nutplates. Riveted on the nutplates and mounted the EMS, and two batteries. For the transponder I used panhead stainless steel screws and locking 10-32 nuts with washers to attach baseplate. Mount transponder to baseplate. Drilled holes for mounting the Ack audio alarm module but didn't have the 4-40 phillips screws and nuts to attach so will have to order those. Mounted the transponder antenna and clecoed the Com1 antenna in place.
