Purged engine again and checked the rocker arm on cyl #1 intake that has been soft in past. Passed test perfectly this time.
Ran engine for about 15 min but could not get oil temp above 122 degrees so could not do electronic ignition tests. Will need to add cowl to get temps higher.
Updated Skyview to latest software and updated to most current FAA files.
Confirmed TRIM was moving backwards. Reversed wires and recalibrated Skyview accordingly.
Re-did fuel test. Was able to remove 3/4 gallon in 90 seconds before running out of fuel in tank
