Brief Description: Installed various wire connectors in firewall area
Installed fuel pressure sensor to firewall and also the regulator and manifold pressure wires to housing. Installed much of the wires to the relays. Also crimped the spade connectors for the EGT probes. Didn't like the connections in a few places so I ordered some new connectors to replace them. As I was tightening a nut on the starter relay with a socket wrench I tightened too much and broke the threaded stud on the relay. Ordered a replacement as well.
