Brief Description: Installed several firewall forward wire harnesses
Installed WH-00063 & 62 as well as WH-RV12-EGT wire harnesses. Most needed lots of wires to be fed through the firewall opening and also the croweded clamp on the avionics shelf.
Cut and installed the tube connector for the pitot tube to be fed thorugh the firewall from the ADHRS.
Prepped the parts for the fuel pressure sensor which I'll install tomorrow. Deburred and primed the bracket that will hold it.
Finally installed the wires into the socket that fits into the Rectifier Regulator (whatever the heck that is for)
Avionics shelf getting crowded with all these wiring harnesses
