Brief Description: Removed center channel hardware
Removed the flap handle asssembly and flapperon push rods. Tight spaces for the tools to fit to loosen all the bolts. Drilled the holds into F-1204A and F-1204D for the grommets and passed the antenna cable through the middle section of the fuselage.
