Brief Description: Re-attached rudder petals and wire guard
Re-attached the rudder pedals. Not at all an easy project as I had to work on my back and hold the blocks with bolts and washers with tape to be able to insert them all. Torqued the bolts. Routed cable through the cushion clamp on the fuel sender. Removed old system blocks and fabricated the F-00049 wire cover plate.
