Brief Description: Installed Fuel Drain tube and hose to engine
Fabricated the Fuel Drain tube and installed it to the engine. Should have removed the forward clamp to do this as when I forced the tube through the loosened clamp I damaged the rubber and needed to replace it with another I had on hand. Will need to order one as I will likely run short later. MS21919DG4.
