Fabricated the two pitch and roll servo assembly sections. Also attached the molex connectors to one of the servos . Seven pins in all, and then bolted the roll servo to the aft end of the fuselage. Torqued the bolts and was pleased with my work. Then re-read the manual and saw that Loctite 242 was called for instead of just torquing the bolts. Will have to source the Loctite as I don't have this one on hand.
