Brent Connelly - N913BC
Date:  5-25-2012
Number of Hours:  2.50
Manual Reference:  29A-08
Brief Description:  Completed Map Box Assembly
Assembled and riveted Map Box. Match drilled it to Panel Base. Tapped nutplates in other sections of panels. Removed upper skin from fuse and completed riveting of battery assembly to upper fuselage that was skipped earlier on. Also installed squeeze rivets AN426-4-3 in the side brackets of the brace where I was missing CS-4-4 rivets before. Flush and stronger replacements.
