Brent Connelly - N913BC
Date:  5-8-2012
Number of Hours:  2.75
Manual Reference:  29A-02 to 29A-03
Brief Description:  Attached F-1201A assembly to fuselage
Completed F-1201A preparation with the completed antenna shelf attachment. Also riveted two nutplates to the assembly before that. Really jumps out with the red color. Will also paint some of the other attachments to this firewall using the red color as well.
With Spencer's help, added high temperature silicone sealant to the lower flange and attached it to the forward lower firewall shelf. Spent time attaching rivets from the inside of the fuselage and then removed the extra sealant as best as I could. Needed to add two nutplates here as well. Also match drilled and riveted the L & R small side hinges to the side skins and firewall assemble.
Began to pull parts for next several steps to being prep of them.
F-1201A upper firewall assembly
Antenna shelf
Antenna shelf
