Began to match drill the piano hinges and also riveted all nutplates to doubler and forward upper fuselage. Did not like the fit of the larger hinge to the doubler and will likely remove and redo this one as I fear that it will make fitting the cowl to it later on much more difficult if it is not perfectly flush to the doubler.
Also applied first coat of red paint to the antenna shelf.
