Brief Description: Finished assembly of rudder petals and brakes
Finished rudder petal assembly. Brass fittings were installed first and then lines were cut to the various lengths. While not easy, was able to install the brass fittings onto all of the lines using boiling water. Finally installed the longer lines to the brakes themselves and used the cushion clamp to attach them to the fuselage. Two of the cylinders are more stiff than the other two - one on left side and other on right. Assume the brake fluid will loosen them up.
Will not install the assembly into the fuselage until after the wiring is installed.
