Brief Description: Began assembly of Rudder Petals & Brakes
Good progress today on rudder petals. Temporarily assembled and match drilled per instructions and got as far as step 8 on 27-03. As you can see, all of the brake cylinders are installed. Will work on brake lines and brass fittings tomorrow. Will not likely install in fuselage now, as this assembly will get in the way of wiring later.
