Here are the completions to date with my daughter Laura modelling for scale. Tips yet to be added as the composite work is typically all done together. I recommend borrowing or splurge-buying a thin nose 'no-hole yoke for the tight leading edges as I tried and failed to negotiate the flush die in while the squeezer was cycling. Hopefully, Vans 'Oops' rivets will suffice in the two locations where the holes were enlarged while drilling out the poorly set rivets.
