This is the pitch servo for my eventual Trutrak ADI pilot 2 autopilot. Studied Vansairforce forum threads awhile before deciding on this configuration. The bracket itself (Steins) was clearly designed for the RV6 and so you must deviate from the installation instructions to use on the RV7. Two rows of rivets and JBWelding to the bottom skin should be sufficient. There's a pronounced angle to the pushrod btw the servo and bellcrank. Trutrak deems that's acceptable, but it offends most builders. I added a few washers so that it clears the bellcrank and one at the servo arm to straighten it out some.
