Bruce's airplane project
RV-7A
sheet 47
Canopy release mechanism fitted
This is the linkage to pull the tip-up canopy hinge pins should you need to eject it after an inverted off-airport landing. Much cutting/fitting to get it all working smoothly. Suspect the release handle will interfere with avionics mounting.
RV-7A Home
549
140
253
144
