BILL'S WEB SITE
Date:  3-31-2019
Number of Hours:  3.75
Brief Description:  Taped fuselage bottom joints
I prep sanded all of the tape joint areas of the fuselage bottom. I then vacuumed it all and wiped with acetone. I cut some wide pieces of BID on the bias for the tapes. I also pre cut peel ply tapes an inch and a half wider than the desired BID tapes I pre-preged the BID and cut the proper width tapes per the plans. I precoated the tape areas with pure resin and then applied the pre-preged tapes. Once all the tapes were applied I added the peel ply tapes. I am really pleased with how the fuselage is coming out. It is arrow straight and looking good!
