BILL'S WEB SITE
Date:  5-30-2018
Brief Description:  Final - Final Adjustments for Bonding
To make sure my firewall was absoluting 90 degrees to the longerons I decided to put some small nylon adjustement screws in the bottom edge of the foam. These screws would act like a stop and allow me to set the firewall with confidence. I bought some 6/32 threaded insert bushings and I floxed those into the foam. Now I could screw in small nylon screws for the stops. One I had everything adjusted and squared up I used super glue to lock the screws in place.
