I glued 36 grit paper to the sanding blocks with contact cement. I then started to shape the bottom corners. First step was a sharp knife from the kitchen. The knife cut well but it took me awhile to become confident on how much to remove. The plans say that it will take about 3 hours to shape all four corners. I spent two and had the two bottom corners kind of roughed out!
