Brief Description: Sanded plugs to shape, started fitting rear seat b
Trimmed and sanded the plugs installed last session flush with fuselage sides.
I then started fitting the rear seat bulkhead. It appears the my LWX pieces may be slightly out of place. My seat back measures out to plans but it would protrude into the center section spar space if position flush to the bottom of the fuselage side. I spent some time working this problem and have decided to intall a .25 wide strip of spruce on the forward side of LWX which will allow the seat back to be flush to the bottom and not protrude into the center section spar area.
