Brief Description: Upper LH Longeron Laminate Trim
Trimmed the RH fuselage longeron reinforcement layups. Fein tool and router with a pattern bit. Pictures tell the story. Router bits and peel ply to do not mix will, better to remove the peel ply, which I did not do, nothing bad happened but had to go back and trim the peel ply after routering.
