Today I put a 10 inch extension on my 8 foot table to facilitate the layup of the fuselage sides. I then drilled a series of holes in the table top to clear a short drywall screw thread. I then laid down a fresh sheet of plastic over the table top. I then put one of the fuselage sides on the table and used drywall screws up from the bottom of the table to pull the fuselage side foam core flat to the table. That worked pretty good! Should make for a nice flat side following inside skin layups.
