Cleaned up after building the fabric roll storage box and the epoxy warming cabinet. Changed the plastic on my work table. Then I cut the fabric for the nine ply uni and bid reinforcements for the forward side of F22 bulkhead. I did this using my router template to trace a pattern on cardboard and then cutting it out with scissors. I used my washer offset technique to make the ply pattern a little larger than the template.
