BILL'S WEB SITE
LT
Install Cables, Wires and Line - static, brake, el
11. Install Cables, Wires and Lines
prep & install tie clips under plane for leanding gear
pilot side - squared front & back 1" below circuit breaker box
Install transponder, gear pump harness under plane
run wing harnesses left & right, left side pitot heat & OAT probe.
Install cable
Installing antenna wire
Running wire under belly of aircraft
LT Home
304
Cabin/Cockpit/Interi
Flight Controls
Propulsion
