Bens Web Site
CH-701SP
Left Wing
11-28-2015
Trailing edge and wing root
Trailing edge drilled while supported by a 2x4. Root angle cut, crimped, and made to fit the #1 rib. The right wing root was coppied and cut out of sheet. Attached at the rear channel and then along the rib down the spar and then down the root rib.
CH-701SP Home
531
144
Left Wing
Right Wing
Tail
25
62
