Used the flaperon template to align the flaperon bracket to the trailing edge where it is clamped. The holes were match drilled from the bracket through the mounting tab. This was done a total of four times. L angles were cut to make the support angles and clamping the support angles to the flaperon bracket and drilled into the wing. The L angles were trimmed to match the rest of the brackets
