Brief Description: Match drilled Right skin with #41 reamer
Reamed the remaining skin rivet holes to #41 per the instruction manual. Disassembled the right HS assembly and drilled the remaining holes into the front spar using the HS-810/814 as a guide with a #30 bit.
