Brief Description: Dimpled HS skins with C-Frame/squeezer
Set up my C-Frame tool and dimpled the HS skins. Used a pnematic sqeezer along the edges to dimple the skins. Had to use a pop rivet dimple die along the first 3-4 holes at the center nose rib where I could not get with the C-Frame due to the bend in the leading edge of the HS skins. Worked ok as long as I sqeezed the pop rivet tool enough. Used a rivet to check the dimples.
