BRANDEN'S WEB SITE
RV-8
Drilled HS-411 assembly to #12
Drilled the rear spar where the HS-411 assembly is bolted on with AN3 bolts to a #12 drill bit. Then I marked the rear spar parts including using a punch to place marks to reorientate the reinforcement bars back onto the rear spar.
Punch marks for alignment later
RV-8 Home
91
Empennage - Elevator
Empennage - Horiz. Stab
Empennage - Rudder
Empennage - Vertical Stab
Non-Building Events
