Brief Description: Riveted the HS-411/VA-146 assembly
After the VA-146 primer was dry I riveted the assembly together. The instructions say that the -5 rivet is the right length, but I found it to be a bit short (unless I mismarked my rivets). I used a -6 rivet that according to my Avery rivet length guide was the perfect size. All the rivets were squeezed and came out perfect.
