Brief Description: Prime and Sanding of the Cowling
I had earlier did some rough sanding of the cowling then did a light primer spray. There were still some areas that needed a better sanding job and I returned to that. I brushed on a layer of Smooth Prime, which does a good job of filling in small pin holes. When dry it is sanded off. I did this a couple of times and ended up with a nice smooth finish.
