There may be some more small adjustments to the fit, but it looks pretty good. The primer I used is a little dark so I may put a ligher coat on the cowling later. Also I'm not sure if the opening for access to the attach pin is what I want as a final look. I may cover this with a small plate. I'll consider that later, maybe after flight testing and prior to painting.
