To fit the lower cowl, the landing gear cutouts need to be made. This is a trial and error process with trimming and fitting repeated until the cutout is correct. Then the rear of the lower cowl was marked for the initial cut, and the cut made. I placed both cowl halves in place and planned for the rest of the fitting process. A lot of cutting and sanding will be necessary to obtain a nice fit.
