Continued fitting and drilling the forward baffle floors and their mounting brackets. Began to fit the Filtered Air Box to the engine and baffle. A hole will be cut into the right baffle floor and an air filter is fitted below the floor, where the air intake box ducts air to the engine intake. The FAB provided with the Van's kit will not fit as shaped. When connected to the engine, the starter interferes and causes the upper end of the box to misalign with the baffle floor. Even without the starter, the FAB does not align properly. I decided to cut the FAB and will layup glass epoxy to reshape it correctly. I cut the FAB into three pieces and began to reshape it.
